Question about PWR/2nd start buttons
Springdale, Ohio
Hey everybody. I have a 97 LC Collectors Edition, it is my first LC, and my first FWD vehicle, so I know pretty much nothing about this stuff. My question/issue is this; The PWR and 2nd start buttons on my console appear to do nothing. No lights on the dash as there should be, and no apparent change in driving when I push the buttons. Otherwise the LC is awesome, drives great with 143k miles, shifts smooth, runs great. Let me know if there is something I should be doing or checking out on this issue. Thanks!
First, have you searched this forum? This forum is full of info, and I'm sure this issue or one similar has been covered.
Second, do you have the factory service manual (FSM) along with the wiring diagram?
Third, are you mechanically proficient? Do you do your own work?
Welcome aboard! Lets see some pics of that LC! :flipoff2:
Polak
when in pwr mode, a green light should appear on the dash that says PWR. also in winter mode, there should be a light that says (i think?) 2nd. does your OD/OFF light work when you engage the button?
might want to pull that switch and check the connections. if those seem OK, perhaps some burnt out bulbs in the dash? the pwr mode will up the shift points on the rev counter and hold gears longer. 2nd gear start...that you should be able to feel the difference off the line. od/off will have high revs @ hwy speed. these changes in patterns might not be so apparent ....esp if the LC is new to you, so they could well be operating.. just without dash indicators.
2nd button is for snow/ice starts. Keeps the wheels from spinning so much.
The power button holds the vehicle in each gear a little longer before shifting. Good for towing.
The search function will enlighten and educate you for almost any tech related question to your 80.
Does your anniv addition have lockers? What color is it and you need to post the picture. Must see!
Welcome by the way :flipoff2: (welcome salute)
Welcome!:flipoff2:
It's not unusual to have a loose connection on the underside of the buttons. Remove the screws holding down the shroud over the shifters and check the electrical connects going to the buttons. It's a start.
FYI, I keep the power button on except in low range where I find it causes harsher shifting.
Welcome :flipoff2:
I'm a newb around here but I've spent a decent amount of time taking my LC apart already ;)
Are the buttons lit when the lights interior lights are on?
If not the connector to the switch may be disconnected under the console - or the dash indicator lights may be blown. The console is easy to remove - just 4 screws at the side corners of the console.
The screw closest to the passenger seat is a longer screw than the other 3 - so note that for re installation ;)
I have had my cruiser for a little over a year and I forgot to look up what those buttons do until I started reading this thread....:doh:.
Thanks guys!!
I had this issue for 2 years. 2 switches and had and electronics guy check it out. Turns out the supply power cable isn't getting the power. I think it's white with black strip. I just used a blue splice tap from the cig lighter soldered it to the power cable on the harness and 3 years later it works like a charm. Tape up the end of the origin supply wire that you cut. Never know when it could suddenly power up again.
I have 285 70 17R tires on my truck and with the increased tire size the performance has suffered but I have been using the power button to keep it in gear longer and I love driving it a lot more. I will be figuring out how it affects my MPG next time I fill up...
I have the 97fzj80 (trip lock) in antique sage pearl. My third and I regret selling my first.
1st) 1989 fj62 with Chevy crate 350 w/700r4.
2nd) (this inherited from my cousin) 1996 fzj green with all the goodies. That was my alaska rig. 38 super scampers on OME lift and all rigged to climb the tundra. Got it on a glacier once or twice too. Word to the wise, never sell your first cruiser.
Had to replace the bulbs for overdrive and pwr on my LX along with the "D" light.
