Question about locking the diffentials
Vancouver BC
I have a question about locking the differentials.
I have a 95 with front and rear lockers and the cdl switch and the pin 7 mod.
Today I tried to climb a grass hill in my buddy's back yard and the tires were slipping. I remember reading in the manual that the diff lock should not be engaged while the wheels are slipping or the diff lock will be damaged..
I wasn't sure if this meant:
a: Back up and lock the diffs before trying to climb the hill
b: let off the gas so there is no power to the wheels and the lock the diffs and then continue up.
I was unsure so I backed up to level ground locked the diffs and then went up the hill.
Which is the correct answer? A or b?
thanks
i think they mean not to have the locker 'waiting' to engage while there is a heavy (fast) load on the diff. ie: trying to climb a hill with heavy throttle. once the gears line up to lock, thats a severe shock load and may damage the diff. you did the right thing in locking them before trying again.
that said, in many instances where a couple tries of an obstacle didnt work and i needed the lockers, ive just flicked the switch, backed down a bit and theyve usually locked with in that time. ive also had them trying to engage during and obstacle, but was very light on the throttle. remember, the gears need to line up before they'll engage, so that means theyll need to slip abit. ideally its under no load (idle speed) or crawling, but a tiny bit of throttle...enough slip to line them up is OK in my book. its not often youll be able to back down from an obstacle, flick the switch and do figure 8s all day long till they engage, but usually flicking the switch, then maybe dropping into neutral while turning the wheel and backing down (to differentiate the spiders to line up) does the trick. it helps that the diffs engage sooner than later, so if you find it takes a while for the light to go solid, a lil investigation or troubleshooting might be in order.
...or if ya wanna cheat, and take the fun out of seeing if you can do it sans lockers...then leave them on all the time ;)
Yes this was exactly what I was thinking. After I backed down, I had to do a couple of dounuts to get them to engage. I felt kinda stupid doing this that is why I asked this question.
Thanks for the helpful reply.
after 2nd or 3rd try, before backing down, flick the switch and back down in neutral, turning the wheel if possible. this should lock it up. if not, might have to exercise em a bit. i find no load but differentiation in the spiders usually does the trick.
Thanks for the tip!
Next time I find myself in that situation, I'll try to roll back in neutral after engaging the switch!
:cheers:
-Jason
If they take that long to engage, they need some exercise - simply engaging and disengaging them a few times a year on gravel whenever you think of it.
DougM
When I first got my truck with lockers, they engaged very slowly. now I just go exercise them for 2 minutes +/- every other tank of gas or so and they engage AND disengage super fast.
They probably do need to be exercised. This is the first time I have used them since the first time I tried them befor buying the 80 an couple of months back.
I will engage them whenever I encounter a gravel road to help them lossen up.
You need to be below 5 mph for the lockers to lock... I have locked the lockers many times while in motion below 5 mph and it is not an issue. The shock load that is mentioned above will not happen because the computer will not let the lockers ingage at a speed high enough for that to be an issue.
ToolsRus taught me this little tid bit. If you think you might need the lockers, go ahead and turn the dial. Even if the light is blinking and they aren't locked yet, move into the obstacle. If you need em they will lock as there will be a little slip. If it turns out you didn't need them, you come through the obstacle with the light blinking.
This assumes the lockers are working as should be and this isn't a high speed obstacle.
Buck
