Question about brass coolant drain plug
So flushed my coolant on our 200,000 mile 94. While I was at it I changed the PHH. It was a bit pesky, using one hand and all.:meh: So my question is I never checked the fit of the brass drain plug on the block. It now sits off of the block about 1/8 to a 1/4 inch. I torqued it to spec and it does not leak. I just wanted to know if this was standard.
:hhmm:
seems like mine sits flush
99% sure they don't fit flush, and that it's pipe threads. Pipe threads means as you screw them in, the threads basically lock and seal versus a traditional fastener you keep turning and the threads don't tighten up until the fastener head hits bottom.
DougM
