Question about Adjustable suspension
Hi, I have a 2006 with the adjustable suspension option.
- What are the reasons behind not being able to drive in the L mode??
- If not bad for the suspension, cv joints, etc, is there a way to turn off the automatic adjustment going into N?
- Same Q about H mode.. is there a way to drive in H over 20 mph?
I'm asking because I was thinking about rasing the car by adjusting the sensors, drive in L mode to have a stable and good looking ride on the street and have the ability to raise the car to serious off-road high when in H!
Thanks for any input!
get slee's little black box if you want to be able to stay in L or H without reverting back to N.
Slee - Electrical Switches
Your CV boots will start to leak if you run in a lifted state all the time, diff drop would be recommended
Thanks, great link!
Leaking CV boots... not worth it then..
Would that be the case if cruising in L mode all the time too?
Especially if I would raise the car (by adjusting the sensors for AHC) about 1 - 2 inches? Wouldn't the L be close to stock N?
Thanks!
Not advised to drive high speeds in LO mode. You will bottom out the suspension. Kabooey. Crash. End of story.
Not sure why you'd want to do this either, why not just run it in N mode? You won't get an extra high mode. The stock front suspension only has 7.5" of total travel. Lift too high and you won't have any down travel.
The reason for rasing it 1-2 inches by moving the sensor together with being able to drive in L is to get a lower or N-type height when driving "normally" while being able to set it in H and get the 1-2 increase of stock H height.
In other words, I want to get it as high as possible in H but without looking like stock-H when driving around in N..
As I'm sure you can tell, I'm new to LC.. My vehicle of choice for modding has been my (now) super charged BMW that is a street monster.. So I thank you for helping a offroad newbie out! :)
You said something about surf and turf at Pismo.. where you referring to my personal trip or is there a get together at Pismo coming up? I'm in San Diego so it would be sweet to meet with fellow LC owners..
Running the ride height any lower than stock on 33's would look kinda strange. I think what you want to do is get your 33's and leave the AHC alone except for Slee's blackbox. When off-road, throw it in HI. When back on pavement, be sure to set it back to N mode as your wheel alignment was set on that height.
Surf-N-Turf is a very large LC gathering at Pismo every November. Go to the trails section for more info.
As for street monsters, I know where you are coming from. I also have a few of my own... (NSX, E46 M3, Turbo Datsun 510). I also swapped cars for the week with a buddy... driving his EVO IV.
Ha ha.. love those little 510s! The turbo "pssst", the super light car.. lots of fun!
I have a kompressor to get brutal tq from 2k and up.. no pssst for me but sure has that typical whine! :)
When you say "get 33's", do you mean get some tires for an 16" rim with an outside diameter of 33"?
For example, the Firestone 285/75/16 has an diameter of about 33". Would that be a good fit? It wouldn't rub even if I drop the LC in L?
Stock is 31" so it would give me 1 more inch on top and 1" increase in ride height.... I think I have about 2" clearance right now between fender and top of tire (stock at 275/60/18).
Would the 285 be too wide? would it clear the fender lip??
November ugh.. Might have to get some rims and tires before then and roll up for sure!
Thanks again for your help!
yes, "33s" are refering to tires with overall diameter of 33".
My 285/75/16s dont rub in low, but i dont drive more then a few feet before it reverts back to normal. You DO NOT want to lock the suspension into LO to drive if you do get the slee box.
Thanks!
I think I like the Firestone MTs then..
Now I just have to find some cheap 16" rims that fit the LC..
I'm searching for the offset of the 2006 OEM rims as a start. Wonder if the OEM rims for a 2001 LC will clear the brake calipers..
