Queensland Australia 80
http://www.karmanshipping.com/australia/ausdotars.html
http://rvcs-prodweb.dot.gov.au/
http://www.dotars.gov.au/
Up until 31st Dec 2002 most states changed to diesel with 500ppm of sulphur previous to this it was 1,300ppm to 5,000ppm in some states.I believe that W.A. and Qld. changed to 50 ppm at this time. By 31st Dec 2005 all states changed to 50 ppm which I believe is Australia wide now for 2006.This is in line with most european countries but we are not inline with the USA yet because we have a higher cetane number.
Thanks for the links. I'm also considering bringing the Merc, which is built before the 1989 deadline and therefore 'may be imported without restriction'... that sounds ok. According to the link, the Lancruiser can be imported without the need to prove that it complies with ADRs, because I meet the criteria (the cruiser and I have lived o/s > 12 months). Someone mentioned that I might need to replace the tyres, which is a bummer because they are new (Falken All Terrains). Does this sound right ? I considered a snorkel but want to find a solution that doesn't involve cutting a hole in the fender...
Here's a picture of the Landcruiser at Nurburgring in Germany. Further down the same link, there's a shot of the instrument cluster, and speedo in miles and kms / hour.
http://forum.difflock.com/discus/messages/128976/156765.html?1142290200
I doubt the speedo would cause any problem as it is marked in kilometers all ready.The air con must be empty if it is fitted with the old gas on older cars or have a compliance tag saying its fitted with the required gas[ see the dotars link].I could not see the tyres being any problem what was the reason given?Do they comply with the compliance plate on the vehicle for speed and load rating?The vehicle will have to be steam cleaned and be free from any dirt or plant matter for quaranteen inspection.There are more problems for a left hand drive car,headlights etc.
Finally got time to go out and give the winch a bit of a test and surprise surprise it didn't blow up. Probably had something to do with the fact that it was only about a 20 degree hill for the first 10 metres and about 30 degrees for the last 5 metres that was almost as smooth as concrete and was doing a double line pull. But this test was only to give the cable a bit of a stretch b4 needing it for real. Whilst winching I only stopped the winch to move the recovery blankets when they got close to the roller fair-leads and when there was about 5 metres left to go removed the blankets and just winched until all the cable was in. Every time I stopped winching to move the blankets I also checked to see how hot the motor was getting but every time it was cool to the touch until after the last 5 metres when it was slightly warm. All up the exercise took about 10 minutes including setting up and packing away. Now all I have to do is get the truck stuck properly and see how the winch performs but at the moment I am quite happy with the performance of this cheap winch. Btw I only have the standard OE battery fitted to this cruiser and have no idea what the cca is but the voltage metre on the dash only dropped a couple of volts when the winch was in use (weather loaded or not the result was the same).:beer:
Bring it - you'll be happy - cars are so expensive down here...
Throw the tyres in the shipping container and eBay them down here. You'll make your money back.
