- Joined
- Jun 2, 2004
- Threads
- 16
- Messages
- 106
It appears that the body tub on my 76 fj40 has "settled" over the years. Probably due the the rusty rear sill area, the weight of the spare tire over time, etc., etc. It looks like the tub sides have splayed outwards a degree or two. This is most noticeable at the gap between the tailgate and quarters. The gap grows slightly larger as it goes up. Today I received new CCOT quarters, and I want to square up the tub prior to welding in the quarters. Can anyone tell me the correct outside left-to-outside right dimension of the tub? Although I don't own a hard top at the present time, I would hate to go through all this and find out later that a hard top doesn't properly fit. I've looked in the chassis FSM but don't see this dimension given. I assume the rollcage will need to be removed, and then pull the tub in with large pipe clamps. Once square I can weld in some scrap angle to hold it in place.
Any thoughts from those who have done this before?
