Q industries MV50 help
VA
I just got an mv50 from amazon. Does anyone know what the air fitting type is? I need extra air fittings to hard mount this unit, it does not appear to have standard fittings. Anyone mount one under the hood? I would like to do that with plans to also put in a 2nd battery at some point. If anyone knows how to contact Q Industries let me know, google does not show anything.
I ended up removing the proprietary fitting and tapping the hole to 1/4" NPT.
I have two of these compressors, so I did it on both.
They just sit back by the tailgate right now, I haven't hard mounted them yet...
check McMaster, they usually have good description of their parts and of the industry standards. Worst case, keep the OEM fitting on with a short pigtail and put in a regular fitting on the hose. Done well should be no problem.
LKA, easy to remove the cylinder head before tapping?
Fairly simple. 4 allen-head bolts and it comes off, along with the valve plate and cylinder itself.
FYI: There's a funky-shaped o-ring on top of the valve plate that can only go in one way... If you decide to turn the head one way or another, the valve plate has to turn with it.
Head on, Head off
The fitting is a high flow type common in Europe, Pacific rim, not common here. Changing it works if needed, but unless your adding a pressure control circuit all fittings/adapters need to be the bleed off type, leak air. If not air pressure can rapidly build and blow fittings, hose, etc with possible injury. Standard fittings/adapters can be drilled to make them bleed off type.
Heat is the biggest enemy of air compressors, so mounting them under the hood isn't the best practice for long life or good performance.
I like these little guys. For once, a sleeper good quality unit from the PRC.
Down to only 2 or 3 myself. These make great Xmas gifts, btw. Just not for that :princess: pretty girl you want to date... :D
Dang, I need to get my arse out to Costco. I saw they had a few of these left for $20 a pop a couple of weeks ago. I was unsure of the quality, but it sounds like they are pretty reliable.
I was thinking about mounting it in my DS rear quater panel above the bottle jack.
Edit:
Lane,
Why do you have two of these compressors?
To double the speed of filling, and double your redundancy.
Makes sense. I don't know where I would put 2 of them, but I think I could get one to fit.
Any idea how long it would it take to fill a 285 up from 15-20PSI to 35-40PSI straight off the compressor with one of these?
Not sure about these specifically, but they are slow. I know that filling 33's with just one approx this size is around 10-15 minutes per tire.
You really wouldn't want to fill them up all the way. They'd be very useful for going from say 15 PSI to 20-25 PSI, so you can run on the highway to the nearest gas station. You wouldn't want to go from 15 to 40 with these though.
You can probably fit three or four behind the passenger's side rear quarter panel.
Really? I take all my tires from 15 to 45 all the time wouthout any problems so far. These little guys are slow but so are most of the gas stations. It's been my experience that most gas stations have weak *** compressors that don't fill any faster than these.
:cheers:
yup, mine will do all 4 tires from 15 to 35 or so in well under 30 mins. More like 20 probably.
