PZJ77 clutch replacement options
NZ
Hi all. I'm after options that might be. out there for a replacement clutch for a 1991 PZJ77. This is a 1PZ engine (5 cyl) mated to a R151F trans.
Is anyone aware of any clutches from another vehicle that'd be compatible? I'm not having a lot of luck searching for a direct replacement. I think I remember reading once that there might be a Toyota Dyna (truck) clutch that worked. I do plan on changing to a single mass flywheel, which I think will make finding a replacement easier.
I've been hunting around a bit, and it seems where I am (NZ) there isn't really anything available that is OEM replacement. There are a few listings for kits that are out of production. I get it, this is a bit of an odd ball combo.
I can get a SMF machined (OG is DMF), so I'm not super worried there, though it would probably be cheaper to find something off the shelf.
I've never met a 1PZ so could well be wrong, but couldn't you use a 1HZ single mass flywheel and clutch from 1HZ/R151 HZJ7# or potentially HZJ105?
