Pwr Steering Cooler - Triage Help Needed!!
Northern VA
Pwr Steering Cooler - Bypass Success update!
Hey guys,
I've got the classic rust-thru on the OEM PS Cooling hardline assembly. :frown: I've searched hi and lo across the archives and my head's gonna burst with all the past experience info I've read today. BTW.... thank you for everything folks have posted thus far.
So here's where I'm at. I've boiled down the vast choices to 2 from Summit Racing: :hhmm:
Fluidyne's FLD-FHP-10026
Fluidyne Fluid Coolers: FLD-FHP-10026 - summitracing.com
and this...
Derale's DER-13222
Derale Frame Rail Transmission Fluid Coolers: DER-13222 - summitracing.com
Has anyone used either of these 2 before?
---supplemental log---- :bang:
I ordered the Fluidyne last night before I was able to post this, and then woke up this morning and called Summit back to change the order to the Derale.
:doh:
I think mounting the 1.5" x 12" x 1.5" pass-thru type cooler to the frame (just below the radiator) will be a tad easier than the Fluidyne's 6" x 14" x 1" non-pass-thru design. I like the idea of the Fluidyne unit's design, being that it's so thin you could squeeze it anywhere....provided you've got 6"x14" of flat real estate.
I'm still looking for feedback on it from anyone out there.
---- present day + coffee ----
In the meantime, the power steering line is still compromised so I'm going nowhere fast at the moment. I've picked up a length of 3/8" hose and plan to bypass the OEM cooling line directly back to the reservoir for the time being until the Derale shows up sometime Wed or Thursday. I spoke the the local dealer's shop foreman and he said given Virginia's current temperature average of 30 degrees, it should be fine without large concern of overheating the pump. Of course, I'll have to take it easy on the driving until then.
Note to self: build a garage so I don't have to do this kind of work lying in the street at sub-freezing temps! :grinpimp:
Has anyone had to do this "bypass" procedure in the past while in out in the field or just when their OEM cooling line deteriorated? I'd imagine so.
Thanks for the input, fellas.
Wow - very timely. Im having the same issue. Im losing about a pint of ps fluid every month. Not good. Interested to hear your results as I will be doing the same job in about a month!
CAUTION!!! Just from my experience. Don't wait too long to order those parts. Mine went from topping off every few weeks to half a quart everytime I started her up. When it goes it goes quick.
Waiting for those parts is a killer when your truck is helplessly sitting there.
But that's just me. I went the oem route bolted right up nice and easy.
I installed that exact Derale cooler on my truck when my OEM cooler went. I mounted it with self tappers on the crossmember, just about where the OEM unit sat. I used a sawzall to cut the OEM inside the engine bay and then plumbed it with 3/8 line. Very happy with the results. Larger capacity, better cooling, and all for under $50.
Well I am now in the position to emphatically reinforce that advice. I've been nursing a slow leak for months now... until Sunday. I came out to find a large puddle and near empty system. When I started her up, I didn't get the usual groan I'd get every other day or so. This time I had a real hard time moving the steering wheel at all, so I shut her right down, filled up the reservoir, fired it back up and rotated the wheels side to side, shut it down and looked.... good steady flow leaking. Topped off the reservoir again and booked it home some 10 miles, only turning when necessary. :eek: BTW the time I got home, I could see a droplet track running back up the street of my block. Shutting her off and doing an inspection showed again steady flow that commenced each time I wiped the lines down. It appears that the line integrity is compromised where the the center support clamp anchors it to the frame. :doh:
So when it goes.... you better have that part waiting for you at home or you're sunk. :crybaby:
On that note, I had done plenty of research through the forums and planned to order the kit from Man-a-Fre, but never pulled the trigger. So when I contacted them and found out that the sub-$30 kit was going to cost me over $100 in shipping to get it from Cali to DC next day, I about shat myself. 2-Day costs were still above $70. Not Man-a-Fre's fault, just the costs of FedEx & UPS. I even checked them on their site to confirm my incredulous shock. BTW, Gonzo @ MAF was very cool helping me out... kudos, man.
So I've scavenged the local auto parts stores and Advance Auto Parts chain, (no NAPA immediately avail), and the only thing I could find are the big oil cooler kits that'd cover up the other half of the radiator (roughly the size of the AC condensor), which was obviously overkill.
So from experience, I'd have to say that if you're in a pinch and located on the East Coast, then Summit Racing would be the source I'd turn to. Great selection, great staff and can get stuff out rapidly. Again, nothing against MAF, I'm just speaking of a distance proximity point for those caught without warning...or are ADD-procrastinators (of the high order) like myself. :meh:
So... if I can extract my butt from the computer (got 3 different ones burning my retinas right now) and into some coldweather gear, I better get out to the street and begin the "bypass procedure". It's gonna start snow/sleeting here shortly (per wunderground.com), and it's gonna suck. :bang:
TTFN!
:beer:
P8nt,
Any idea what the overall capacity was when you added the Derale to the system?
I need to make sure I've got enough ATF on me to refill the system when I swap it out.
I've been trying to mentally picture how I'm going to do the bypass, ie... where I'll make the cut. I have to assume that the reservoir is by now empty from the flow over the night out the cooler line crack. So cutting away the line from the bottom (the SMALL ONE towards the front if I'm right, else I'll compromise the high pressure side, right? Or are they both Low Pressure lines attached to the reservoir?) shouldn't make too much of a mess. The question is will the gearbox retain the ATF currently in there when I cut the hose off at that nipple?
I've been keeping it filled now with some red ATF that they guys at the dealership hooked my up with. Don't know what the stock fluid is used by the dealerships.... anyone know?
TTFN!
:beer:
With that said... my wife notified me that it just started raining. :doh:
:bang:
Where's that tarp!!??!:censor:
P8nt,
I not sure on exact capacity, but I would say it was a marginal difference at best.
I pretty sure everything were working on is on the low pressure side. Someone correct me if im wrong.
As far as where to make the cut: If you remove the splash guard from under the truck you should be able to see the OEM cooler lines running in parallel down the DS, beside the grill. I think I made my cut just before the lines passed from the engine bay to the outside.
I can take pics if you need, but its damn cold out!
Thanks for the responses, guys.
I've been out at it for some time now. Sun's gone down and so's the temp.
Been taking pics all along. I've got the lines unhooked (no cutting of OEM soft lines), and unmounted the "hanger" that secures both the low and high pressure line pairs against the left side of the frame. I'll be removing the OEM cooler line next and reconnecting the reservoir to the box after that.
I'll check in later.
The neighbors are really having a fun time watching this circus. I actually put up my pop-up tent (the ones that fold out and up 10x10 with no sides) to prepare for rain/snow. Only sprinkled for a short bit. But I've got it lit up with lights hanging from the supports. LOL.
I'll take a pic for posterity.
Cheers.
:beer::beer:
Bypass Procedure Success!!
It's alive!!!
It took a while, but the bypass is done. I removed the eroded OEM cooler line and re-plumbed the return to the reservoir.
I didn't have my sawzall handy, so the demo work was done with more sweat equity than I'd normally bother with. :bang:
I also sorted out that you can use one of the original low pressure lines to connect the box back to the reservoir! Very cool considering if you're out in the wild and somehow damage your OEM cooler line. Just use the one with the 90 degree bend in it, and it'll reach back up to the reservoir's nipple. Don't think I've read that little tidbit before. :idea:
I took a ton of photos, so hopefully I'll get to uploading them soon.
I'll check back in when the Derale cooler arrives from Summit in the next 2 days.
Thanks to everyone's replies. They helped alot. :clap:
Cheers.
:beer::beer::beer:
Have you had a chance to post the pics?
RescueU, garages aren' all they'er cracked up to be. Most garages I am personally familiar with are too cramed full of s***e to be usefull for working on a vehicle the size of a FZJ80. My garage is full of tools and I work on my truck in the drive way; however, I have been know to rearange the whole thing to fit my truck in there when it was too cold/rainy to work outside. I say that feeling silly about it because I live in Florida and it hasn't snowed here since 1994. But sometimes it really does get cold.
Anyhoo, great write-up. Looking forward to pics.
