PWR Seat Stuck
My wife moved my LX last night and this morning when I tried to move the seat back, it made some crunch sounds and wouldnt move. Is there a way to manually move the seat back to drive it? Anyone else had this problem? Thanks
I don't think there is any manual override for the seat. I seem to recall others having problem moving the seat, but it required taking the seat out to see what the problem is...(do a search and see if you find anything)
Cheers, Hugh
maxnharry:
I had the same problem several months ago. Assuming it's mechanical and not electrical, yours may be the same problem I experienced.
I removed the seat, found the problem to be a little plastic gear housing on the front drive assembly, opposite the drive motor. It's a right-angle thing, and it has a nylon screw which holds tension on a shaft. (poor description, but I'm not sure how else to describe it.) Talked with my favorite parts guru, who advised me it was the ONLY serviceable part that could be replaced (otherwise ya' gotta' get the whole frame).
You may want to PM CDan...he'll know the part. Easy job, seat removal being the most difficult part.
STOP!
Don't try to move it. Take out the four bolts holding the seat down and pull the seat. You likely have something stuck somewhere and if you continue to try to move it back/forward you could mess up that plastic gear or do other damage.
Well I had to recline the seat all the way back to flat to drive home.....got home and pulled the seat. It was that plastic right angle thingie. Apparently the forward portion moves but not the backward portion. The motor seems to be fine. I used a pair of channel locks to manually move the screw back and reinstalled the seat. I will have to PM my favorite parts guy for a quote on the part.
An offer ....
Maxnharry:
I started thinking about your problem, and realized that I actually have my old right-angle-plastic-gear-thingy....Mine was not broken, but rather was missing the little plastic, threaded 'plug'. After replacing the unit with one from Dan, I actually found the 'plug', and I think the unit is perfectly fine.
If you'd like it, PM me, and I'll ship it to ya'.
Finally joined the Forum after taking advantage of the great technical help for a number of months. My 1995 FZJ80 thanks you!
I'm missing the infamous little cap/screw that applies pressure to the (electric) front seat drive shaft. Both seats actually stopped working, but I found 1 of the plugs.
From a prior thread, CDan (?) or Maxnharry has these, can get them or made some from aluminum.
How do I contact them and/or does anyone know how/where to order this part?
Thanks in advance for your help-
