1) Any issues with wiring the pusher fan so it comes on anytime the engine is running?
2) Anyone install 2 pusher fans on the condensor? Would one fit behind the transmission cooler?
My buddy did an e-fan conversion on his R50 Nissan Pathfinder. No more clutch, just a continuous running electric fan. Got a bit more power on tap, plus (he says) it stays cooler.
I'm thinking of putting in a pusher fan... Wiring it to the A/C, a temp sensor, AND a manual On/Off/Auto override switch to control it all.
A couple relays, a few yards of 10AWG wire, and a bit of solder should do it....can't be that hard....who needs a controller when you can build your own?![]()
