Thanks for quick responses. Man - got me stumped but it is purple no doubt about it. I haven't had rad flushed in a long time (hate to admit). I will go ahead and install new rad, etc., bypass rear heater, etc. (waiting on parts) and go through flush again see what happens. If I eventually get clear water coming out of new rad drain plug then we will know I had tran fluid leak in radiator. If not, then ... FSBO
ive never seen a vehicle leak anything purple lol, so congrats on that....Im not toally sure but I assume transmission fluid could leak into radiator if the cooler or radiator failed but either way it would just make a darker red ( red trans fluid + Red or pink coolant ) or if for some reason you were running green coolant ( don't ) and it mixed then you would be getting a brown
Is this vehicle new to you? Maybe someone used that fancy overprice royal purple stuff, do they make coolant? Just guessing h
I will give you more detail below
I have owned '98 since 2006 - got it under 100k miles. Did the water pump, drive belt, etc when I bought.
All maint done along the way by Master Mechanic at dealer - friend of mine so I can trust it was done right. In 5/2014 at 192k miles did new radiator, hoses, tran flush. At 247k I did the full camshaft, timing belt, water, pump seal again, all 3 diff oil change, brake fluid and p/s fluid flush. Sitting at 340k miles now. I am about to change out the rad, hoses, bypass rear heater, I have done the basic stuff on LC - valve cover gaskets, plugs, at 283k. Clean rig no rust. Had to do front end ds shaft replacement a couple times. Last one at 326k. Replaced all door lock actuators... been fun project ride - removed running boards / put flaps up front - .... bout it. Most of this has nothing to do with my current issue but it is 100 degrees in MS and I am working on "dehydration" ... lol. Still not as tough as my '74 FJ40 but a challenge none-the-less.
Anyway - I'll keep you guys posted on what I find after I swap out rad for new one. Thanks for input.
