Just a quick sanity check:
I pulled the drivers side door panel last night and the wiring for the upper tweeter and lower door speaker are a pair of purple and pink wires. From what I've read, it sounds like they are just spliced together in the door panel harness. I'm assuming it's parallel wiring (purple to purple, pink to pink)?
This seems to make sense, since the door speaker (JBL) is labelled as a 2ohm speaker, and the tweeter probably is too? Wiring them in parallel would take a 4ohm amp load and convert it to 2ohms per door speaker.
From the photos I've seen, it looks like most people just disconnect the upper (pink & purple) harness completely and just leave it hanging there, then run the factory lower harness to the replacement crossover....which then sends new wiring to the upper and lower speakers.
Have I interpreted that correctly?
-G
-G
