Pulsing throttle
Salt Lake City, UT
I am in the middle of desmogging my 79 40. My 40 has sat for a several months and prior to starting the desmog I noticed a problem with my engine idle. My 40 was fine and running strong 6 months ago. Starts fine but when the engine warms with the choke out it starts to pulse at fast idle speed. I don't have a tac but I am guessing that is in the range of 1500 to 2200 rpms. It revs and drops and repeats very rhythmically. When I push the choke in and let it idle at normal opp temp it idles just fine. I was hoping that this problem would disappear with the desmog. I should be 100% finished with the desmog tomorrow evening. This is really pissing me off. I have spoke MAF and several others and people just say that just weird! ITS WEIRD but I am going to Moab on the 2nd of June and really could use some advice on fixing this. If anyone has had this problem I would sure like to hear what it was and how it was fixed. :doh:
If you are running the 2 wire idle solenoid.. try this.. the white wire w/black stripe is the ground.. cut it & ground it to the carb or other good source..
Thanks I'll try it ! Would you think that the solenoid possibly has a poor connection?
Its fixed! I think the solenoid had some crap in it. Tested it and put it back together. Bueno!
