pulsating clutch
Kelowna, BC
Occasionally and most often when I have been using the clutch a lot (off-road or around town in heavy traffic), when depressed the clutch pedal feels like it pulsates -- kind of feels like a momentary reduction of pressure on the pedal. What might this be -- the clutch master cylinder leaking ?
Would be it be also linked to another occasional problem I have, when I turn the key off the engine does not shut-off. Both problems are intermittent.
It could be your clutch disc is out of whack.
If your clutch is powered by vacuum and your shutdown system uses vacuum there might be some link.
