Pulling to the left
Ingerland
My new truck pulls to the left. Not so that I have to hang onto the steering wheel, but enough to be annoying.
Bear in mind that I drive on the left so the road camber could be a cause. But I have the same issue on a three lane road when driving in the middle lane so probably camber is not the cause.
I have checked tyre pressures - any suggestions as to what to try next?
Thanks, Jim
Hmmmm. I read about Woody's incident - that's what prompted me to investigate. It could be a brake dragging, it could be a wheel bearing, it could be steering. I was just asking for some other ideas to think about. ..
no. I am waiting for some reconditioned alloys - I thought I would wait till I have them on before going for an alignment. Do you think that's wise?
Mine had a slight pull too, ended up being the Parking brakes/rear brakes were dragging. Fixed them and the pull is gone..
After a bit of driving, preferably highway, stop and see if any of the wheels / rotors getting abnormally hot. Telltale of brake dragging.
Do the other checks first. There is only 1 thingt on an 80 that can be adjusted during an "alignment" and that is toe-in. I would eliminate the things you've mentioned first; brakes dragging, loose wheel bearing or bad knuckle bearing and maybe do a tyre rotation.
If all those check out OK then take it in for an alignment and save all the numbers (caster, camber, toe, and thrust angle) so you will have a baseline in case you later decide on a lift or other chassis changes.
-B-
I used to do a lot of highway driving, and was in the habit of checking the temps of my wheels when I stopped for gas. I never really felt much heat, even on hot days, just a little warmth from the brakes.
