Pulling seized engine, leave torque converter attached?
wi
I searched, didn't find any answers so I'm putting this in it's own thread for future reference.
When pulling the engine, normally the TC gets unbolted and left on the trans. When the engine doesn't spin, you can't unbolt it...
Apart from an ATF bath, is there anything else I need to watch for while pulling the engine with the TC still attached?
be careful not to damage the transmission oil pump with the tc
Yep, pull it out as straight as possible, binding it can damage the pump bushing.
Just to follow up.
The 'showerf atf' is overrated, more of a slow dribble and can be easily caught in an oil pan.
About 1-2qts came out in the process with more still in the TC
I just rebuilt mine. I left the converter on the trans. It was very easy both ways. Pull the radiator and the water pump or at least the water pump studs. I had the studs in, putting engine in and had to watch them carefully. The only issue I had was putting the rear engine lift bracket on backwards. It hits the fire wall if you do. That was 30 mins of unneeded struggle.
Putting the bolts back in the converter, I had a friend turn over the motor with a socket (plugs out). There's a small plastic adapter on the converter hub. Make sure that's there.
Scott
Edit: oop's. (reading is fundamental) just noticed "seized engine". Well you can put it together with converter on trans.
