Pulling in grooves
Hello Everyone,
I haven’t posted in a while; I have a question for you guys. I have a 1993 LC with a tad over 300,000 on her. My rig seems to pull from left to right when I hit a groove in the road. I have an old man 2.5 lift on her and everything else is pretty much original. Is this something I should be concerned with and if so where should I start? Any help would be great!!!
Thanks
I have almost 4" of lift without caaster correction and my rig will wander sometimes when I hit grooves in the road especialy with bigger tires.
I do not know how much caster will affect this with 2.5" of lift, but it is where I would start.
What size tires are you running?
Bigger tires seem to want to follow the grooves in the road more than a stock size tire.
Others will also chime in as well I am sure.
X2 on Caster correction. Until you have the numbers checked at an alignment shop, you will not know what correction-path to follow. With the 2.5" lift you may be able to get away with OME bushings, or Slee Blue's, but may need to install LandTank Plates. Again, you will need to first find out how bad the Caster is off, then choose which setup will get you back into factory specs...then your rig will fell much more stable (and safe) on the road .
:cheers:
Steve
worn radius arm bushes will cause that. not enough caster will cause wandering, but generally not pulling or 'tramlining' like you say.
replacing with 2 degree caster bushes will help in both instances. but not totally necessary on a 94 model.
do yourself a favour and replace all the bushes (6 radius arm bushes and 2 panhard bushes). at 300k they can't be too good.
some food for thought:
get rubber castor correction bushes, poly bushes don't flex very well.
the genuine toyota bushes are generally best for flex (but expensive), though there are good poly bushes out there. Super Pro poly bushes are good if you can get them.
thanks for the suggestions everyone....i just order a new bushing kit and i will start there 1st......
