pulling engine
Texas
can you lift the engine out with trans and transfer case attached and where is the lift point?
That's very often the recommended way. The lift points on a factory engine are hooks on opposite corners of the head. Rear driver's side and front passenger's side IIRC.
The transmission on a 1980-earlier FJ40 is attached to the engine ONLY. There is no crossmember attaching it to the frame. So it has to either fall off the back of the engine onto the floor, or come out w/ the engine.
I find it easier to split and then reassemble the engine/tranny on the floor, so pull the engine & tranny out of the truck in unit.
