Pulling dash
Central NC
I have an outside temp gauge like this one (in pic) that I want to install, but what is the extent of dash/steering etc. that needs to be removed (manual says bunches)
edit...forgot to give credit for the photo. It came from the thread I cited below
Yup, you just need to remove the screws holding in that one large piece under the steering wheel, and pop it out. Very simple/straightforward. You can remove the switch panel area by just pulling that top piece out, but it is not needed. Just stick your finger up through the bottom and push outwards on the switch blank, and you should have enough room to work.
