Pulled code(s) for check eng. light-Help!
Try explaining that again.
You inserted the paper clip in the E1, TE1 slots and it blinked eight times with a 1.5 second pause then three times? That would be an 83 code. There is no 8 code alone, no 3 code alone, no 88 code alone and no 19 code alone.
The 83 code is a TCM Communication code. Faulty idle siginal. ESA 1 circut. I have no experience with that code so I hope other experts will chime in. :cheers:
Yes , it would blink 8-times,8-times,then the 3-times.Just like that seemed to be the pattern.
I can check it again tomorrow,maybe pull that one fuse to reset& check.
Thanks for the reply, John
