MUDShip Pull Trailer from UP down south
aaronrules
Coolest person you know!
Greenwood, AR
Hey all, I am trying to find someone that can pull a pop-up camper that I am buying off of @yoopermike. It is located in McMillian Michigan. I live around Fort Smith Arkansas. I would be willing to drive to meet whoever is pulling the trailer down if you are not going very close my neck of the woods.
The details of the camper are here:
craigslist - 2011 Jayco Baja 12e
The trailer is right at 3,000 lbs as it sits. Mike can/will correct me if I'm off on that number. I am willing to pay if it's reasonable. The quoted numbers on Uship are sky high, and I'm throwing a line out there to see if anyone can help!
Thanks
That is correct on the weight. Dry it is listed at 3025 lbs with a 420 lb hitch weight. There will be some additional stuff that might add up to an additional couple hundred pounds (battery, WDH, mostly full propane tanks, etc.). I never tested it on any scales, but it just barely squats my 1/2 ton Silverado to just above level in the back without a WDH.
