Pull to the right
The Saratoga slums, CA
Since I bought my 97 FZJ80 w/ 102k mi 2 1/2 years ago I’ve had an annoying pull to the right which I haven’t been able to cure. The pull was there before I bought the truck and I figured it was a wheel bearing issue or an alignment issue. However, after completely servicing the axles, installing a lift, changing tires and brakes, I still have the pull. The pull is fairly strong; i.e.: if I let go of the steering wheel I’ll drift completely into the next lane in 5-6 seconds at moderate speed. The pull will also become significantly stronger if I engage the front locker. Having the rear or center diff engaged doesn’t affect it.
Since I have serviced just about everything on the axles and because of the increased pull with the locker engaged, I am beginning to think the problem is a misaligned spindle/knuckle or bent axle housing. My thought is that if the axle is not centered in the spindle on the right knuckle it may by causing excess drag and thus causing the pull to the right.
When I serviced the front knuckles, I didn’t see any evidence of excess wear to the bushing or the birfield nor did I notice any evidence of heat build up, but I guess it may be worthwhile to have another look. I’m also skeptical of a bent housing as this truck hasn’t been wheeled hard yet and was never in an accident according to carfax and visual inspection.
Here is what I’ve done so far since owning the rig. Nothing I’ve done so far has had any influence on the pull.
1. Complete service of front and rear axles, including new wheel bearings, trunion bearings, axle seals, knuckle seals and swapping birfields from left to right. I didn’t replace spindle bushings at that time since visual inspection looked fine. There were no stripped splines on hubs, birfs or axles.
2. Brake job w/ 100 series pads in front. Removed, cleaned and lubricated pistons. Recently replaced pads again after 30k miles. No uneven wear.
3. Installed Slee 6” lift. This was the complete kit including control arms, adjustable front and rear panhard rods and adjustable rear upper control arms. I made several adjustments to fine tune the axles so that they are perfectly centered under the frame and made sure the distance from front hub to rear hubs was equal on both sides.
4. Replaced stock tires with 36 x 12.5 TSL radials. Rotated the tires several times. Made sure all tires are inflated equally.
5. 4.88’s
6. Adjusted toe in several times.
7. Replaced drag link and tie rod ends.
Most of the suggestions I've read in previous threads involve worn or misadjusted wheel bearings, rod ends, sticking brakes or improper tire inflation. If anyone has some other ideas, I’d love to hear them before I start digging into the front end again.
Have you serviced your rear brakes?
Twice.
The brake job listed as #2. above included front and rear. Full tear down, clean, lube, turned rotors, parking brake service and pads when I bought the rig and new pads again recently after 30k miles. No effect on the pull.
I have a similar pull to the right. It started immediately after a flat tire which I didn't witness. My princess called me to a parking lot to change out a front right tire with a 4" gash through the tread block. "It just happened." When she was pulling out of the parking space, someone pointed it out.
The tires are now slightly mismatched and if the tire pressure is not close, it pulls pretty hard.
Doesn't really help, does it?
5 to 6 seconds for a lane change from the left lane to the right lane doesn't sound too bad. Most roads have a cross slope of about 1/4" per foot (2%) for drainage, so vehicles naturally pull to the right. If you drive on the left side of a 2-lane road, does it stay put?
4 wheel alignment?! You mention you may need one at the begining but I don't see you had it done.
My toe in on my left rear tire is way too far... I know there is no adjustment, so this is probably why my truck pulls.
I'd shoot for an alignment to see what your numbers are...
Have you figured out the pull since I have the same problem. Thanks.
can you offer up a castor reading? Often one side has a little more/less caster than the other which is supposed to compensate for the crown in the road (from what i have read and been told). So if your's is different in a large way, or on the other hand not different, then i would venture to guess that could be something to look at.
That's a good point. I will go for alignment when I have some time. Thanks.
