Even after all the new parts, first check for fluid leaks on the inside of all 4 tires. If leaking, you'll see streaks radiating outward. If no leaks, I would consider replacing the brake hoses. They can be blocked internally, and even worse, they can create a one way valve that holds pressure on a caliper even after you let your foot off the brake. Other possibility is sticking caliper pistons. I have had someone stand beside the roadway as I drove by and hit the brakes pretty hard. The observer can tell you which wheels locked up, and which ones didn't. Sometimes it's a matter of eliminating the possibilities. If it's your rear brakes acting up, make sure they are both adjusted equally with a slight drag with no pressure on the brake pedal (and the hoses back there may be the culprit). Good Luck
Doug
