puking coolant
Boulder, CO
97 80 series, gasser. 114k. Original HG. Did the phh and full coolant flush with new oem thermostat and gasket 9 months ago. The truck has been running great since, and I've noticed no problems with the UN-modded temp guage, which I plan to mod when I have the time. After driving 25 minutes up lefthand canyon near Lyons, CO I pulled over to the side of the road to air down. After probably 10 minutes I made my way to the PS front tire and heard a gurgling, or so I thought. Then there was no sound, and then I heard the gurgling again. Noticed a few drops of nice Toyota red coolant running out onto the ground. Popped the hood and sure enough, the radiator is boiling and the overflow tank is full to the point of overflowing. Start the truck back up, and within 1 minute or so, the coolant level goes back down to normal. I have not noticed any problems since.
From some searching, it seems that I should probably replace the radiator cap with a new OEM one (currently have an OEM cap and it appears to be in fine condition), and should also go ahead and install that blue fan clutch that I've had sitting in the box for the last 11 months :doh: I'm prepared to do the HG and get it out of the way if it's time, but I'm not sure that it's time just yet. I'm debating on whether or not to have my new blue fan clutch modded by LandTank as well.
One other thing... I coincidentally did the "bubble test" the same day that all of this happened, prior to departing for the trail, and I noticed no bubbles, so I'm really leaning towards the fan clutch + rad cap combo at the moment. Thanks in advance for any help.
I agree that the cap is suspect. A new fan clutch is a good thing too, so basically it looks like you are headed in the right direction.
-B-
