PTO winch for 40 series near Vancouver, BC (1 Viewer)
Kimberley, BC
SOLD!!!
I have a 40 series PTO winch for sale. Includes winch, cable, shifter, shaft assy and PTO. Minor modification will need to be made to the shaft length to fit your truck. I am assuming this because I only held it in place on my truck and it seemed just short...or long(cant remember since it was last year!) May just be that it is for a gas powered 40 and not a diesel. it looked like the brackets would bolt right up to the frame. The winch bolts on to the top of the frame. The PTO fits a split case.
$800 pick-up preferred, but willing to ship
Japan
How does that shifter fit up to the tunnel? I have the same set-up yet to be installed- but on mine the shaft is 2 parts- not 3. Were these all removed from the same truck? Nice looking set!
Pete
Kimberley, BC
Pete, From laying under the truck, I believe the shifter mounts to the frame and then goes through a hole in the floor on the left side of the tranny hump. This kit was pieced together so it may be different than stock, i'm not sure. When i temporarily threw the winch on the front and the shaft into position, i think it was either too long by an inch or two. It looked like the shaft bracket would line up with the holes in the frame rail. Again, that was a year ago, so with all of the other projects that seem to take my attention also, i dont exactly remember.
I believe the PTO should fit onto a split case, but i am not 100% sure of the differences between the non split and split cases in the PTO area.
Petzel
Pete
Japan
is the bolt pattern symmetrical or slightly offset on the pto/transfer mating flange? is this forward as well as reverse?
That will tell you if it is for a split case or not. I think the 3 piece shaft is either from a 55/60- not a 40- though they may be able to be made to work. There has been a similar setup for sale at the same price for almost a year- so you might consider either breaking the set or shipping if you want to move it. Especially since the split case take off seems to be rather hard to find- especially if it has reverse. In fact if you do break it up I'd be interested for the shifter/cable as mine is shot. Best to keep the PTO and the shifter as a set though.
Pete
Kimberley, BC
Ok...back from holidays...
The PTO fits a split case. It only has forward, no reverse.
I will update my firt post with this info as well.
Users Who Are Viewing This Thread (Users: 0, Guests: 1)
