Does anyone know the Toyota part number for the PTO "U" joint and if they are still available?
did the ones from the FJ55steering that you got from sledge work?
All the "U" joints I've ever done have seals at the roller bearings, does this one use the "O" rings there instead?
The dealer here in Guatemala had it in stock!.....
...Did you only get a spider and a bag of cups? I have a bag of "O" rings and snap rings too....
..What are the "O" rings for? All the "U" joints I've ever done have seals at the roller bearings, does this one use the "O" rings there instead?
Is there an instruction sheet in your package? Mine has been on the shelf for years by the looks of it and there is no instructions any longer. I have not opened it so I'm not sure if the installation is clear or not. A "normal" "U" joint is pretty simple but if these are fragile even when pumping in grease I don't want to mess it up.
Maybe someone can scan and post it if they have an instruction sheet.
But you'll have no problems fitting them and you won't damage them if you take it gently with the grease gun (and don't let anyone else grease them).
