pto question
The West
I have a 1970 fj with a 2f . I am looking for a pto winch for it and came accross one for 500 but its from a 72 fj40 with f engine. will it fit mine. ive heard that the older ptos dont fit newer engines. thanx foir the advise. :idea:
As stated previously it runs off the transfer case. What you will need to do though is get the 4spd pto gear which is easy to find assuming that you are running the cruiser 4spd tranny. If you are running the 4spd tranny you will also have to extend the PTO shaft because the 4spd tranny is 2"s longer than the 3spd tranny. Other wise everything else is bolt on. Make sure that it comes with the pillow blocks under the rear cross brace.
Travis
Also double check to see if the PTO setup is a Ramsey. This uses a different PTO drive, that I don't believe is compatible with 4spd transmissions (except maybe the 74 4spd?).
Either way, if you still have the 3spd you're probably okay.
