PTO Gearbox Seals
Houston, TX
Both the shift rod shaft in the back and the output shaft on my PTO gearbox are leaking. Can I replace these without removing the gearbox or is removing the box easier. Not having worked on these, I was worried about gear alignment etc when replacing the box. Also can anyone tell me what seals I need? Thanks
Pull it off, dead simple, no drama to re-install.
Need to know what year and model to get the seals right. Single output or front and rear sort of thing.
The 80 boxes are very different from the 70 series boxes.
The gearbox is on my 1970 but I have no way of knowing whether it is original or not. The box does have a rear output. Then it has two shift rods in the back connected by a linkage. The lower shift rod and the front output are leaking. Does this help identify my boz as a 70 series or 80 series. I didn't even know there were different types. Thanks
Not exactly. Mine does not have the small square boss with the plug in it which is just below the long shaft extension in the picture. Otherwise it appears to be the same.
