Just a reminder to check and make sure that your rear locker vent tube is not clogged and breathing properly.
I just replaced mine because of corrosion due to the end of the breather tube being clogged.
I had no idea that the breathing end was located between the body and frame at the left rear wheel well.
Pics are attached. I pulled it out a tad so you can get a visual.
The front actuator vent is more protected.
Now I need to check the CDL actuator.
I'm assuming it has a vent as well.
