PS question
Hi All:
Ian, do you own the JTO Saginaw bracket yet?
If "yes," then have someone weld the tensioner nut on securely - the one bogger weld that it comes with most likely will fail in short order.
If "no," I'd suggest sourcing the bracket from another vender - "Classic Cruisers" in Colorado sells a Saginaw bracket, as does "Mudrak Custom Cruisers" in California.
Good luck with the project!
Regards,
Alan
Seattle
Yeah I have the bracket already, thanks for the heads up. :cheers:
Can I booty fab my existing 76 steering column to work with this setup? Or is there a better way to go?
