PS Pump help
NorCal
Removed the old factory PSP and tried to transfer the little half circle tab to the new OEM pump. It was a little too thick so polished the sides a tiny bit. Slid it in and can't get the gear to seat at the depth previously measured. I've hammered the top with a socket good. Any ideas?
Hammering on the input is never a good idea, it's only supported by a ball bearing, likely to damage it. Have done dozens of them and never measured one. The shaft and gear are tapered, if installed correctly and torqued to spec, that is where it needs to be.
What year?
94
I ended up getting it on with a leather glove and an impact. The gap is pretty much spot on. Measured original gap with a 5/8 wrench for reference and it fits just the same. Fingers crossed.
Yeah definitely had air. When I ran it loud whining. Turned engine off jacked it up and continued to turn left and right for a while. Didnt see fluid going down so ran it again and no whining. I'll check for leaks tomorrow morning. I'm new to wrenching so it's all a learning experience.
