PS on an F
Sedro Woolley WA
Yes
There are kits you can buy for mounting a Saginaw PS pump on an F motor. If memory serves me, you will end up replacing the stock air cleaner as the two pieces will try to occupy the same space. I believe most will use the two front head bolts on the driver’s side to secure the mounting bracket.
I fabbed up my own brackets for mounting a Saginaw pump and it was a lot of work to fit it in. I ended up moving the alternator to the passenger side of the motor and placing the pump where the alternator used to be. Oh, I also used every mounting bolt on the water pump to help secure every thing back down. There definitely aren’t many places to bolt stuff to the front of an F motor. :P
G_Stratton said:
Yes
This is exactly how I had to do mine. I made a bracket similar to the one JTO sells, and removed the generator (old F) added a GM alternator to the passenger side. Mounting the alternator was challenging to say the least. I need to do some more mods to it, but for now it works.
I used Mark's Offroad (65swb45) saginaw pump mount. Kept my "F" air cleaner, moved the alternator to the PS with a "2F" alternator bracket, 2-groove harmonic balancer, '76 "2F" waterpump w/ 2-groove pulley, Alternator belt goes on the outside groove and PS on the inner one. Fabbing up an adjustment bracket for the PS pump was a head-scratcher, but what I did works well (see pic).
The problems you will have are with the steering column and making that work. I used Bill Dorry's gearbox bracket. I had to put the gearbox as far as I could to the top to make everything "fit". I used my original column tube and steering wheel with the shaft out of a '76 steering column tha thas the rag joint piece on the end. That '76 shaft will fit in the '72 column once you cut 6" off the tube. You need the bronze bushing from the Downey "early model" kit to put in the end of the tube that centers the shaft on the engine compartment end. I did not brace the tube at the firewall. It is solidly fixed to the steering box and I used two screws through the dash brace to locate the shaft at the dash. The setup is solid and I've wheeled it hard with no ill effects.
This is an unconventional approach to the steering column in an early model PS conversion, but it's simple and requires NO WELDING. Simply bolt on. I labored over this decision for a month or more trying to figure out if it would all work. I believe my solution is very reasonable.
If you have any specific questions, don't hesitate to ask...
Jody.
