PS leak need advice
High Desert, SoCal
Need some advice on the use of a sealant on a power steering fitting. I have a slight leak where the high pressure line connects to the pump. It is a flare fitting and a new hose. I have tightened the thing as far as I believe it can safely be done. I was researching and found that loctite 545 might work. Has anyone had any experience with this product or have any other solutions?
Thanks Brad
The flare makes the seal; the threads only secure the female and male pieces of the flare fittings together. Using any kind of thread sealant is only going to be a band-aid at best in the event that it works.
Have you removed the hose and inspected the seat in the pump to make sure that something has not damaged the sealing area on the male part of the seat? That fitting will back out of the pump, just be mindful of the spring and washers that may be in there. I would look at that, as it is likely the cause of your leak. Make sure that you have not damaged the fitting on your new hose.
In the event that the little brass-fitting piece in the pump where your pressure line attaches is damaged, you can swap that out with a similar piece from another pump, as they are interchangeable.
Find out what is going on and fix it properly.
You will get it!
Good luck!
-Steve
Thanks guys
I didn't know that the pump seat backed out. Will check it out later today.
Brad
