Ps idler pulley assembly
I use the Toy pump too, but here is the big issue the saginaw has high pressure and high flow. The toy pump has low flow but high pressure. For the pully you may also want to look at toy pickups, with some fab you may be able to make it work. The 3b PS system is a hard one to find.
Buddy Darwin found me one locally. That was the final piece of the puzzle needed for the ps conversion.
Thanks to all that tried to help.
I'm in the same predicament. Post up what you find, if you please. I looked into this a year ago but didn't look into trying to find one off another application.
From my research here are some leads for you:
- Sheldon at G&S Cruiser Parts http://www.gscruiserparts.com/
- Ray at Specter Off Road https://www.google.ca/#q=specter+off+road
- Guy named Mike that another member gave me his info on. He wrote:
"Hi found bracket and took the brg assy off of a 1hdt
There is a small spacer that spaces the brg that requires removal of 2mm or less that 1/8th of and inch material.
The bracket was purchased for a someone in Washington and then he would not pick it up."
His email: Mike McTague mikemct@shaw.ca
Tell these guys Noel sent ya.
G'luck!
