PS Courtesy Switch replacement help needed
Scottsdale, Az
So I have the random dome light on turns along with door unlocking issue. I searched and found out it's most likely the PS front courtesy switch so I picked one up at a Toyota dealer. I cannot tell how it unplugs from the plastic connector to save my life. I'm worried I'll cause damage if I don't ask on here first.
Thanks.
sharp pick or precision flat head (tiny) between the connector halves- kind of pulling the outer sheath from the inner halve's catch nub and pull
Thanks.
Do you have a part number for this, I have the same issue! :)
I have a tiny flat head. So I use it to lift the outer sheath off the inner halve's catch hub by finding a good spot to pry? I was going that direction but I didn't want to break the plastic.
I'll post up the part number when I get home tonight. If you're impatient or on the way to the dealer today then ask for the courtesy switch for the passenger front door. I think it was about $25 for the switch.
84231-60020
Thanks Onur :)
As a side note, my headlights no longer turn off when I open the door, is this part of the same issue or something else? My green circular light around the ignition lock does not turn on either (maybe finally burned out?).
