PS cooler for FJ40
Hi All:
I went down to a local auto wrecker, all ready to buy a used auto trans cooler, etc. to use as a fluid cooler with the Saginaw P/S swap on my FJ40. The yard guy wanted $25 for the used cooler!
Next, I drove to the nearby "Shucks" (dba "Checkers," etc.) auto parts store and bought a new cooler that came with hoses, cjamps, etc. for like $19.95!
Mount the generic cooler in front of the radiator, the supplied hoses were plenty long.
HTH.
Regards,
Alan
Seattle
Most kits come w/ 2 pull thru fastener straps and a backing. Check out the kits, pretty self-explanitory. All you do is strap it to the radiator. Man-A-Fre has a kit for about the same price.
G-luck
Campy
I mounted mine right like this
its just a small trany cooler, maybe $30
I bought a generic transmisson cooler from CarQuest for...$29.95 and used the pull-through straps/zipties and mounted it in front of the radiator. The only caveat from CarQuest was to pull the plastic ZipTies really, Really TIGHT. Like not with just your hand. I funcrumed with an open end wrench and a pair of dikes. Otherwise it will vibrate and chew a hole on either the cooler or the radiator. I cut my ties off, but not flush, so's I still had something to grab when the rubber washers compressed and it needed tightening. Adds an extra pint or so of Dextron and may help.
GL
Ed
