Purchased my first round of OTS parts (springs, ball bearings, filter fabric, o-rings, etc.) to begin prototyping! I have a digital manometer on its way as well, and this week I'll begin check valve prototypes. I'm targeting ~.4PSI cracking pressure for tank pressure -> canister, and .1-.2PSI cracking pressure for the purge check valve and makeup-air check valve (canister to tank).
Also, here's more pics from the design process. The copper-colored part shows reinforcement ribs for what will make up a honeycomb lattice, this supports/compresses the charcoal bed (and filter fabric) while allowing vapors to pass through:
Based on what I know at this point, I'll have two different sizes/designs, so that they fit in with existing brackets if the owner still has them:
- Pre 09/77: A "short" model approximately 100mm in diameter, somewhere between 120-140mm in height. This model would only have two ports on top (tank and purge).
- 09/77 / later: A "tall" model approximately 120mm in diameter, somewhere between 170-190mm in height. This model will have a larger, 3rd port up top (the carb port, shown in the pics above) to be a drop-in for folks that have their original carb / emissions equipment. Easily blocked-off for de-smogged builds that use carbs (such as the cityracer aftermarket replacement) that don't have fuel bowl vent ports on their carbs.
I'll be modifying the vertical sizing to achieve a similar charcoal bed volume as the OEM part #s.
Next up, modeling check-valve prototypes and bracketry. Im guessing that initial runs of brackets I sell will be glass-reinforced Nylon PA6, and if I can find a manufacturer I'll shoot for steel replacements in the long-run. The closest bracket I was able to find is from McMaster Carr for a sobering $130 per bracket. Yikes... Off-the-shelf doesn't look like a viable option, so manufacturing it is...
Lastly, I've been learning FreeCAD as part of this process. It's open-source and allows you to save your work locally as opposed to the cloud, which fits into my whole self-sufficiency philosophy, but boy howdy is there a cost to go with the principled route... It's about 300% harder than Fusion360 in my estimation. not sure if there's any 3D modelers out there, but thought I'd share. Keeping my recurring cost manageable is a big part of how I can make these parts affordable, but I seem to have chosen the path of pain, ha.
