Properly greasing drivetrain
Tustin, California
Hey guys, still new to this and want to gain some clarity after going through old posts and only seeing various different opinions.
I recently greased the u-joints and slip yokes on my 80, using Lucas Red & Tacky multi purpose chassis grease under the recommendation of some others. After doing this, I can hear quit a bit more of drivetrain noise when laying off the accelerator at slow speeds. Is this something to worry about? Its my first time doing something like this, now I am worried I created an issue out of nothing.
Should i grease with Valvoline MP moly grease? I added 3-4 pumps of the lucas to the driveshaft to discover the FSM recommending moly for the slip yokes. I didn't see any grease being pushed passed the old seal with the exception of some old black grease, a very very small amount. If my seals are functioning as normal, is it safe to pump the old stuff past the seal?
Thanks so much for all the technical help. This forum and community is like no other place i've ever seen, and stoked to have my 80 for years to come.
Grease the driveshafts until they just start to move. If you already pumped a bunch in there and want to get it out before it causes problems, put the truck on ramps and remove the bolts on front of each driveshaft and pump out the extra and then hook them back up. You can go nuts on the u-joints.
Is Lucas Red N Tacky a decent grease to use for both the driveshaft & u-joints? I popped the zerks off of both driveshafts, a tiny amount came out of the rear and none came out of the front. Should i add more?
I have no knowledge of this ever being done and although the PO was into maintenance all of the drivetrain was dry and the zerks dirty.
Want to add I didnt add much grease, maybe 2-3 pumps in the driveshaft and heard no popping and saw almost no movement.
If you haven't had any driveline problems or noises, just grease the shaft and drive it. Take it apart and clean it, then grease it when you have time on your hands. Change out the U-joints when they fail the wiggle test; ignore mileage and age replacement schedules - they're designed by manufacturers to move their products.
Grease U-joints until the grease comes out, 2-3 pumps of a standard grease gun for the slip joint, no more.
Some greases are maybe better than others, depending on your driving habits and environment, but if you keep the joints greased regularly (and every time they're submerged), you'll be fine with whatever you like. Many people want to use a specific product for every application; I can't be bothered to keep that many tubs around (I don't run a commercial shop). I use bearing grease for bearings and multipurpose red for everything else.
my 2¢
The red and tacky is fine. There are probably other better greases, maybe more thick and less prone to getting slung around.
Most likely your u-joints are original, and most likely the previous owners didn't lubricate them at all. There is a good chance they are worn and need replacement. If the grease didn't fix it (at least for temporary purposes), you're most likely going to want to replace the U-joints.
In my opinion, the job was a little annoying actually. I enjoyed it when I was finished though! No more clunk feelings and vibrations!
When you grease your drive line you should do it with it UNLOADED...That means chock the wheels, put it in neutral, then grease it. This is that rotationally it will be unloaded and the slip joints won't be binding and the u joints won't be tight.
I use a moly based grease (Valvoline Palladium) for sliding surfaces like the slip joints and a Lucas Red. N Tacky 2 for the u joints.
2-3 pumps for slip joints and 4-5 pumps for u joints. Don't go crazy on the u joints because it just makes a mess and it the grease it being forced out, then there's a path for dirt to get in.
On the slip joints, use a old pen or a dull screwdriver to push on the center ball of the zerk to release the pressure.
I have used the Lucas Red n tacky for 12 years on my yokes and ujoints. No problems thus far. Car has the original joints and 170k miles on it.
