Once again I will check it out more tonight. But my buddy that helped to get the engine fired, said that the accelerator pump did not seem to be squirting.
I rebuilt the carb, put in new plunger and all. I want to make sure that I have done it right and didnt misinterpert the book.
I put the small ball bearing in to the retaining clip and the bottom of the shaft, so bearing wont move. is that supposed to hold the ball bearing lie that, or is it supposed to float in the cavity?? Is the small ball that comes in the kit the one to use?
I could not get the stopper out of the other cavity to even make sure that the ball bearing was in that one. Only thing not fully cleaned or checked. and the ball bearings were the only thing not clear.
Exactly how does the accelerator set up. what is the purpose of the ball bearing.
What can I do to get gas pumping. Float is at proper level, Is the pump stuck closed, if so how do i get it to open.
Thanks, Mike
Thanks, Mike
