Project .79 Rear Coil Conversion
AU
deleted
deleted
i seen another guy on 4wdaction put 80's hubs on 79 diffs to get the 6 stud wheel pattern so im presumming you can also reverse it to get the 5 stud wheel pattern on the rear (79 hubs on 80's diff),so its same as the front, or you could just buy two new 6 stud pattern rims for the rear. dont worry about different diff widths n sh-it, as nike says, JUST DO IT. lol
good luck.
good stuff man, i tried to use those lips that are folded back on the crossmember to weld to but ended up making a new one, was easier for me.. and yer just measure the inside chassis widths and cut out a section in the flat part of the crossmember near passenger coil hat. good luck ,and yes wreckers are ripoff cu-nts.
