Curious if anyone here knows of any 1Fz-fe builds using a ProCharger setup for boost rather then a turbo. I don’t wanna start the battle of which is better, just looking for ideas.
No, they don't have one. They are made four miles from my house and I have stopped in and had a chat.
To look at the debate part, a turbo from Wit's End would be better anyway. Procharger uses a different operation, but still relies on the belt to turn it, dropping HP and delaying boost.
Not looking for a kit, just searching around if anyone has made there own setup. It’s clear turbo is much more efficient and provides more overall power, although there is alittle more simplicity in going with a centrifugal charger. There’s no hot end piping required, the intake airtemps are much cooler, less clutter in the engine bay, less heat in the engine bay, and if one is only looking to boost up to 7-8 psi a correctly sized procharger would be able to do this relatively efficiently.
I will be building a charged 1fzfe for my 80 and will most likely end up going with the wits end kit, although I do have a procharger P1SC-1 that I’m currently not using and was kicking around the idea of using it for the build, was mainly curious to see if something like this has been done to gather some mounting ideas.
