Problems with starter actuator.
Bonsall, CA
So I've been having the common clicking problem and replaced the starter contacts and plunger. Well, that didn't help me at all. Sometimes I need to turn the key on and off for 3 minutes before it suddenly starts.
I tore the starter motor apart and everything is fine. While I was there I replaced one of the bearings and cleaned everything.
The actuator also looks good but when I applied current it only trembled slightly but never moved. I needed to push the plunger by hand and at one point it seemed to finally catch the magnetic wave and clicked.
What could be the reason for this? Is seems like the coil is not strong enough to pull the plunger (everything is lubed so no friction issues).
Currently I simply glued a thick piece or rubber to the actuator cover so that the plunger sits w few milimeters down. This is a redneck DIY approach so I would prefer to solve the problem rather than cure the symptoms like I just did.
I had a similar problem that started six months after rebuilding my starter. The only fix in my case was a "new" remanufactured Toyota starter. I was disappointed the rebuild didn't last but now my truck starts right up and I don't worry about a total failure in the field.
