Problem with Mels
Bonita, Tx
Am installing a Mel's ignition kit on my 75 FJ40. Everything bolts right up, magnetic
sleeve is going as far as it is supposed to, but now rotor is too tall and cap won't
bolt back on. Saw where someone took the grinder to the magnetic sleeve. Any
other suggestions guys? Cap and rotor are fairly new after market replacements.
push the mels down
I did the conversion about 5 yrs ago and ran into the same problem. If I remeembur right you need to make sure that you are using the correct magnet thingy in the dizzy, ie different heights, and make double sure that it is all the way pushed down. Is the rotor an OEM?
my pertronix (basically the same thing as the Mels) magnet had the same problem. The magnet has to be in a certain position or it does not seat completely. The rotor will not work unless the magnet is all the way seated.
Did you get it working? What was your outcome? I just ordered the Mel's kit and will be installing it this weekend. They didn't tell me I needed a new coil but I'm thinking I should upgrade my coil to a high output versus the factory style coil by looking at some of the other kits sold by spector and others.
Never got it to fit right......ended up installing an HEI distributor. Money well spent. :cheers:
Get a pre 1975 dizzy and use it wih the pertronix setup. You will not have problem with the cap and rotor. I ran the mel's kit on my 1975 fj55 with a 69 distributor with no problems. Get the flamethrower coisl also.
Just wanted to throw an update out there on the Mel's. When I was looking at info on the Mel's this is one of the few threads I found. I installed the Mel's on my 67 FJ40 and it went in rather easy with the exception of getting a screw to go through the ground wire of the magnetic pickup to the distributer base. The directions tell you to ground it using the condenser screw which is two threads or so to short. I had to machine a screw to fit. I replaced the coil with a 40K Volt coil from Autozone they carried MSD. The truck fired right up. It runs much stronger than with the point setup, maybe the old points needed to be adjusted but I'm very happy with the results. I do wish they would supply the right screws to go with the kits I spent more time fumbling with screws and machining them to work. If the screw was to long it prohibited the vaccume advance from working and the tolerances are very tight. I'll post some pics to help the next guy. These threads are a big help when your scratching your head for anwsers.
