Problem with brakes - Help!!
Detroit
About 2 months ago, I had to replace RR caliper which had the caliper piston riding on the rotor. Somehow the brake pad had worked its way loose. Since the rotor was gouged to shreds, I replaced both rear rotors and put on new rear pads both sides.
I only bled the RR caliper back then, with an assistant. Pedal was firm.
A week ago, I noticed the "brake" light come on. MC was running low, topped it up. 3 days ago, light came back on, MC was low again.
Today, I found out that the line to the caliper I replaced in january was leaking. I tightened it, then bled RR and the proportioning valve at the back. I had nobody to help me, I just did a gravity bleed since I don't have the vacuum pump thingy.
The tests I have done:
1) with engine off, brake pedal goes to the floor; with engine on, it goes to the floor much faster and easier.
2) with engine off, I cannot get a stiff brake pedal no matter how hard I pump.
The car stops but stopping distance is longer.
I have read all the archives here, but I don't want to buy anything fancy. Question is will a total bleed (4 calipers + lspv + mc) improve matters? The fluid is cloudy. I wonder if the ABS has a bleed nipple on the accumulator somewhere. I also hope the booster isn't shot.
Any ideas? Will give it another shot tomorrow, with an assistant.
The vehicle is a 1996 landcruiser with ABS, 168K miles.
