Problem installing rear aussie locker
Scottsdale, AZ
Hi, sorenoneill again.
I installed the locker apparently thinking everything was cool. But as I began to drive and turn the cruiser I heard and felt as if the drivers side axle was kicking back or out. I can turn right with no noise, but when I turn left it continues knock. I parked it removed the diff cover and everything looks normal. THough when I read the instructions again they mentioned the thrust wahers need to stay. I am confused. Are the thrust washers the washer swhere the spider gears sit, because those are the only ones I removed. If someone could help that would be great.!!!!!!
Sorenoneill
the thrust washers are the brass dimpled washers on the side gears, not the spiders. the spiders and their washers get removed completely.
your locker will "tick" when you turn and will occasionally unload in anything from a klunking to a shake your vehicle/scare the crap out of you way.
Shortly after posting my problem I figured out the washer issue and had indeed left out the passenger side one. But the only sound I hear is something that can only be described as a subtle click but when I look at the locker as a friend is turning the tire I really don't see it doing much. Sorry for all the questions.
Sorenoneill
It's very important to take the measurements as described in the manual and make sure that the thrust washers are of appropriate thicknesses. You did get out the feeler guages and do that, right?
3pits said:
how long would it have taken you?
cost?
where did you get it from?
did clicking go away?
takes about an hour, they run 239+ shipping now, i think the website is offroadlockers.com, but don't quote me on that, the clicking won't ever go away, you'll notice that when turning as the locker bypasses to allow the tires to turn at two different speeds.
I've got a lock right in the rear of my FJ40.
I never noticed it until I went wheeling the first time.
Then I was happy I had it.
I do hear the click but I've gotten used to it.
About the only thing I don't like about it is when I am on the freeway and get on the gas sometimes the truck will try to change lanes on me... But with a little care, that doesn't happen. I just can't drive my truck like a sports car... hehehe :D
