Primer pump
Logan
Need to replace hand primer pump on the 80 series 1990 1hz+t diesel leaks when you prime pump what primer pump do you recommend? Genuine? Is aftermarket okay? And should I replace anything else while I change primer pump
I went genuine because I'm a bit of a genuine parts snob, but honestly an aftermarket one is probably just as good for a part like this at a fraction of the cost. Just won't give you that nice warm fuzzy feeling you get seeing the Toyota logo on the box.
I'd do the rubber hoses to/from the pump at the same time. And yes, I did them genuine too. Yes, I have a problem. :)
