Good evening all,
94 Turbod HZJ80R 80 Series
Just did new Injectors Torqued with Copper grease seated no issues. Fuel lines clamped back down no issues no apparent leaks. Followed Roscos advice on bleeding via the glow plug holes this was very effective at keeping the fuel lines sealed.
Primer pump was replaced as old one was leaking, hose size on original took 12mm hose new one only takes 8mm.
As a lot of gear is upgraded to turn the HZ into a HD I’m wondering if the change from factory size is affecting power under load. Do I need to use a 1HDT Primer that take 12mm fuel hoses as this is the size found at the INJPMP and at the feed from the Fuel tanks.
My cruiser is fine at the low end but anything over 75kmh it is struggling with up hill and it feels as though the pump is starved of fuel.
This could be an old topic just trying to figure this out before spending more money
Regard Lew.
Regard Lew.
