Pretty white smoke
Fayetteville, Arkansas
Well, I've never had a question until now. I've read for countless hours & days & weeks on here. All my questions have been answered until now.
97 LC
175K
Owned for last 150 miles
Doubt PO did much more than oil change
White exhaust smoke on start up. Smells of fuel & maybe a little sweet? However, it disappears by the time I get to end of the neighborhood. (lasts longer if I just let it idle in driveway). I was also having high engine temps but NO coolant loss (200-215*F just leaving neighborhood in 20-30*F ambient temp). This made me think HG for sure.
So,
This weekend I replaced: plugs, wires, cap, rotor, radiator, T-stat, water pump, PHH bypass, LandTank blue clutch, belts, hoses & switched to Zerex Asian Red coolant after a distilled water run and flush. Amazingly, the vehicle now won't climb past 181.4*F. However, the white smoke on start up remains.
- I will be sending off a BlackStone sample in a few days.
- spark plugs all came out equally dirty. (not steam cleaned)
- No coolant loss
- Negative pH bubble test for exhaust gas in coolant
- Have not done compression test
- No milk under oil filler cap
Is it safe to say I might just have some leaky valve seals?
Does anyone know if it is possible for a HG leak to produce white smoke ONLY during warm up ? I was under the impression that a HG leak would produce white exhaust during the entire time the engine was running.
You described the smoke as a fuel, sweet smell. That is VERY typical of coolant in the combustion.
Yes, it is possible for there to be coolant only during start-up. The head gasket is on its way out. Overnight, the temp cools down and the tolerances open up. A few drips work their way into cylinder #6. When you start it, you actually have a liquid sitting on the top of your piston. When you crank it over, the liquid gets pushed out to the exhaust where it sits in the catalytic converter until it heats up and vaporizes. You must watch this carefully, because one morning your engine will not turn over, but will come to a sudden and abrupt halt while attempting to turn it over. This will be hydrolocked.
Based on only start-up, I would lean toward a cracked head rather than a HG.
Once the truck starts, the cylinder pressure is higher than the cooling system pressure, and the coolant does not leak into the cylinder. After it warms up, it's possible that the tolerances close up and it no longer leaks.
Unless you are describing the vapor that condenses in the exhaust on high humidity days when it has really cooled off at night, then you are looking toward a HG job, possibly with a cracked head.
Is this you DD or is it sitting for a week or two at a time?
Just drive it as you are and wait the the Blackstone report. That will tell all. Blue smoke on startup is valve stem seals. White is coolant and easily mistaken for water burning off from condensation in the exhaust.
Amazing how much a cooling system overhaul changes coolant temps. After my PM I run about 181 in the winter too around town. 190 in the summer
"Is this you DD or is it sitting for a week or two at a time?"
This vehicle sits for weeks at a time.
Is it possible it's just moisture in the exhaust from high humidity and cool conditions? There are supposed to be weep holes in the bottom of the exhaust to let out the drips of water, but if they are clogged, the moisture may be building up, and the fuel / sweet smell is from burning out through the cats.
It may be absolutely nothing.
Do a Blackstone analysis and that will give a good window into what may be happening.
Thank you for the suggestions so far!
It seems the HG isn't always a complete failure & that is reflected in the sometimes "small" amount of symptoms a bad HG might produce.
The fact that I don't have a few of the usually noticeable characteristics of a blown HG is slightly reassuring. However, I guess the BlackStone test will provide me with the factual evidence I'm looking for.
Where are the weep holes in the exhaust located ?
Also, my vehicle had new exhaust from cats on back about 2 years ago....Maybe the aftermarket exhaust doesn't have weep holes ?
The weep hole is in the bottom of the factory muffler at the bottom rear. It was designed so after shut-down, the moisture would condense and drip out the bottom so there would not be any moisture in it at start-up and it would not cause the nasty acids inside the exhaust caused by binding with the sulphur in the exhaust, causing highly corrosive sulfides that will eat through steel.
Odds are that an aftermarket system does NOT have the weep holes in it dues to not knowing the final orientation of an aftermarket part. Don't drill one in it because you don't know the internals of the muffler and you may expose raw steel that you don't want exposed.
