prepping panama tubs
God's Country
just talked to my paint rep, and he says it you use clean n' etch from www.diamnondvogel.com, you can apply this with a hudson sprayer, powerwash it(let it dry or course).
He then said you can use any paint system you want. From my experience if you don't prep galv. Paint will NOT stick.
put this out there because I plan on working with the panama tub.
nice guy.:beer:
You do have to do some specific prep for Galvanized steel, go with what your jobber recommends for the paint system you'll be using.
I'm using DuPont Chroma Premier when I paint my Panama tub, and the tech guy at DuPont recommended an etching primer, then an epoxy and then the ChromaPremier single stage paint..
You should be able to check on the tech sheets for your primers to make sure they are compatable with galvanized steel.
